Another typically vague bit in the MS manual...
I understand you use one of the 4 user configurable outputs (1-4) and configure it in megatune as required. Whats vague is where you pick up the
dupplies from on the board.
Where are X4 and X5 located? There are references to JS2 and JS3 as well for these outputs, which are located next to the processor. Are these what
are used?
But then it also refers to JS0 as the fan control, but I cannot see anywhere in Megatune to configure this output or get into the fan settings as they
are greyed out permanently in the settings page.
Any help greatly appreciated.
Sorry I can't help with the internal wiring as ChrisW sorted mine.
The Fan control is under "Basic settings" - "Codebase and Output functions" X2 changes from "water injection to fan
control" and you know where to set the temps.
ATB Dan.
[Edited on 6/5/09 by scutter]
