Right, I has something remarkably like this sitting in my car, and it needs a fuel
pump.
As far as I can tell, I basically have 2 (relatively cheap) options, a 3 bar (43.5psi) pump, and a 7 bar (101.5psi) pump.
And it seems the gpz1100 likes about 35PSI, according to googlefu.
So, 2 questions;
Am I thinking in something approaching sane?
If so, which is likely to be better, given I'll be running a regulator anyway.
Cheers.
[Edited repeatedly, by a dozy Staple balls]
[Edited on 31/5/09 by Staple balls]
Go for a standard bosch type HP pump which are usually 6 bar, then regulate it down to 3 bar.
Clicky
