I've got my retest sva retest tommorow, (only emmisions). I failed last time as the powercommander seemed to have no effect at all. It was then
that I noticed that underneath the serial number displayed on the power commander control panel, it was showing device error 18 and if I then reset
the commander, device error 17 appeared. I sent the power commander back to dynojet to be checked, and it was supposed to have had its firmware
updated, I have just got back from trying it for the first time as I have only just got my replacement loom and ecu from malc (another story), and
it's displaying device errors exactly the same. It then dawned on me maybe the commander is not compatible with vista, any ideas, time is not on
my side.
Regards Simon
Sorry no suggestions but power commander III USB is definatly compatable with vista
Just googled it. Codes 17 & 18 are to do with the EXUP servo motor. Hope it helps.
Code error
[Edited on 31/5/09 by l0c0st]
Thanks l0c0st, but the device error is not on the R1 clocks it is on program that controls the power commander, thanks though.
Regsrds Simon
