What does the MS tach output signal look like, is it pulsed or analogue?
Many Thanks
Its a 5 or 12v square wave depending where you pick your power up from.
I used this diagram
http://www.msextra.com/manuals/MS_Extra_Hardware_Manual.htm#tachoout
With two 1Kohm resistors and picked up the power form the S12c point on the board.
[Edited on 8/7/09 by flak monkey]
David, did you use this method to power a VDO rev counter?....I can't seem to get mine working...
I tried that other method but could not get it to work...that said...I didn't try too hard, as I run a digital rev counter also, but I want to
get rid of this and go back to the VDO...
Cheers for the link anyway.
Paul.
