Had a problem with fuel being weak at top end, changed regulator still the same, changed fuel pump for cosworth one. only to find its now running way to rich tried dataloging all morning to no avail. Only to find i had a crack in a vacuum pipe, put it wright now ok all through rev band.
Sounds like a good day to me. You've ended the day with the car working better than it did this morning.
Cups half full...
Mark is definatly right!!!!
You had a great day, your problem is solved, though of course it is frustrating to spend money on buying parts that were not really need/not the cause
of the problem!
Hi Mate!
Sounds like a good day to me that means its ready for next weekend are you going?
http://www.locostbuilders.co.uk/viewthread.php?tid=117805
My bad days usually end in failure and frustration.
