Right.....help please. Can someone please explain in simple terms the difference between MS V1 2.2 & 3.0??
I'm fitting R6 TB's to 1.8 Zetec.....what'll I need Megasquirt wise?
Thanks,
Matt
PS -have 1.8 Zetec fly so can use for the crank position sensor.
2.2 and 3.0 refer to the main board, 3.0 is re-designed and better than the original allegedly. The main differences refer to the versions MS, and
they are MS1 and MS2, MS2 uses a different processor and has a number of enhancements, it also costs more than MS1
hope that helps.
MS 1 V3 will do the job more than adequately, im running R6 TB's on my Pinto & i run the MS1 V3 setup with edis & coil pack
Sorry I can't help, but I'm confused by the same question.
Can MS1 v3 be used to adjust the ignition advance with an edis?
How about this? Good value???
http://cgi.ebay.co.uk/Megasquirt-1-V3-Brand-new-ECU-Extra-Code-loaded_W0QQitemZ120478072841QQcmdZViewItemQQptZUK_Body_Shop_Supplies_Paint?hash=item1c0
d0d8009&_trksid=p3286.c0.m14
I would have thought you would be better talking to Phil here
http://www.extraefi.co.uk/ms1_products.htm
Then he could build you a megasquirt which will do what you want rather than a generic build. MS1 is more that up to the job you want.
http://cgi.ebay.co.uk/Megasquirt-1-V3-Brand-new-ECU-Extra-Code-loaded_W0QQitemZ120478072841QQcmdZViewItemQQptZUK_Body_Shop_Supplies_Paint?hash=item1c0 d0d8009&_trksid=p3286.c0.m14
Any one want to do a group buy
link
[Edited on 15/10/09 by big_wasa]
Yes it can be used with the Edis system but so can all the others , mine is running on a MS1 V2.2 with the Edis mods.
The main difference between V2.2 and V3 is that V3s have more tolerance for set up and wiring faults as the circuitry is better protected.
Paul
I've written up my experiences of converting to bike TB's plus megasquirt on my website. There's a link somewhere nearby (at the
bottom of the post I think...). You might find the odd useful snippet.
[Edited on 15/10/09 by fatbaldbloke]
