Hi
I have a ford efi manifold with a stock idle valve.
I am using a megasquirt. I have just got the car runnig at it looks like the idle valve may not be working or set up correctly.
Can anyone recommend a way of checking the valve is working and does anyone have the settings for the idle valve on the megasquirt.
thanks
Frank
http://www.msextra.com/doc/ms1extra/MS_Extra_Manual_Index.htm#download
the above site may be of help.
for ms1 extra
just started my ms coversion so not yet sorted the idle valve out.
edit if NOT MS1 EXTRA then --
http://www.megamanual.com/mtabcon.htm
[Edited on 29/11/09 by Paul (Notts)]
bit on extraefi web site, if using a standard manifold set up could have used a standard ford ECUlink
Not sure but I think that the only way you can test is to stick another one on. Just looked through the fault finding details and can find nothing on it. Ray
