hi all, just wondering what version megasquirt will i need to run a duratec on throttle bodies?
thanks
stuart
surely any version will do it?
Any version
I am using MS1
cool, i was not sure i have been reading on a few places and just getting confused.
thanks guys
stuart
mtech automotive are doing a group buy on the latest V4 version might be worth a look they get good write up from the ford boys
http://passionford.com/forum/traders-parts-for-sale/311319-m-tech-v4-ecu-group-buy-1-more-definate-needed.html
You may want to do some home work before spending your hard earned with the above
Not that I have ever used them.
Consider Microsquirt
By far the cheapest option is to use a MS1 on a V3 board. If you buy it from Phil at extraEFI you can specify the various options.
I had my set-up done by Mtech and while the work got done it took longer than expect and some of the none ECU work wasn't to a very high
standard. If you fit it yourself and then take the car to MTech to get it mapped you would be OK.
hmm, thanks for all teh input will do some more resarch and no doubt ask more question on here.
cheers
stuart
