hi all, i have a 2.2 megasquirt to run my duratec, so first question is what software do i need to tune it on?
and how do i connenected it to it, i have the lead i was wondering is there a process?
thanks
stuart
there is 2 different software packages i used to tune mine, Megatune and Tunerstudio. But when you take a datalog you need Megalog viewer. The different packages tell you what they want with regards to connecting it to the ECU
You can download the software from <here> or
<here>.
Ed.
You will need to run MSnS (squirt and spark) MS Extra code to run both the fuelling and ignition side.
I have done a rough ar$e base map for my charged duratec which wouldnt need much fiddling to change to NA if you want me to do one for you? (Comes
with no gurantees though and I will need to know a few things about your ecu).
You also need to decide what route you are going down for the ignition side. Whether you want to go edis or built in coil drivers.
hi, thanks right i think i downloaded all the right software, as i got it as a tunning package very think i need.
u2u david.
stuart
Hi Stuart,
You need to have a look here:
http://www.msextra.com
At the manuals as there are internal mods you need to do to the unit in order to use it with EDIS.
If you are unsure about doing the mods yourself, get in touch with Phil at extraefi (google it) and ask him to give you a price to configure the ECU
for you. This is probably the easiest thing in all fairness.
Read the manuals carfefully, but only those parts that relate to your install otherwise its gets very confusing.
Hi Stuart,
