I still havnt been able to find a reducer suitable for fuel that i can use to join my 51mm filler cap and my 45mm tank.
Someone suggested using a coolant reducer which i did only to be told that it needed to be fuel resistant
Does anyone know where i can find one?
Failing that, has anyone got a 45mm filler cap (preferable lockable) i can buy?
what about a metal reducer ?
(+ 2 short bits of fuel resistant hose)
[Edited on 22/12/09 by mcerd1]
Where can i get them from? I have looked but havnt managed to find any.
make your own ?
failing that sketch something up and see if someone on here could do it for you
(I could but I'm not sure what stock metal I've got just now)
why lockable?? The days of nicking fuel are gone are they not? Its not like the car is going to be parked outside overnight is it?
Originally posted by MakeEverything
why lockable?? The days of nicking fuel are gone are they not? Its not like the car is going to be parked outside overnight is it?![]()
Originally posted by mcerd1
make your own ?![]()
failing that sketck something up and see if someone on here could do it for you
how about this?
Bit of 50mm fuel hose should be able to be persuaded over your 51mm filler
^^ thats what I had in mind, but made to your spec if you couldn't find a suitable one
get flak monkey to machine one for you .
i could roll some stainless , but i aint back at work until jan 4th.
Originally posted by speedyxjs
Not sure how to make one myself.
I've bloody well TWICE before told you how to do this!!!
http://www.locostbuilders.co.uk/viewthread.php?tid=122896
http://www.locostbuilders.co.uk/viewthread.php?tid=126088
James
