I read a post some time ago where some builders had bonded their tanks in - MKs I think. With the pump, breather and filler on the top of my tank,
I'm not sure whether there will be room for the 'traditional' straps. How have you sttached your tank and any feedback on the
legality/advisability/durability of bonding one in (notwithstanding my previous thread about making the tank removable.....). Thank once again!!!
JC
i have bonded mine on, filler and breather is on top and the fuel pump is in the middle underneath.
mk only bond theres on aswell and dont use straps anymore
Mine has 3 or 4 pieces of ali angle welded to the bottom which is then bolted to the chassis. Seems to work well.
Tank also sits on, and is isolated from the chassis by some high density neoprene foam.
Sorry but this bonding thing still seems wrong
matt (procomp) has posted before about people who have metal tabs welded onto the bottom of the tank. In racing accidents the tabs stay attached to
the chassis and rip off the tank - spilling the flamable contents on the track.
Straps are supposed to be a little more reliable in that sort of situation.
I used rubber from a conveyer belt to protect the tank from the straps. Very strong rubber backed onto a woven material. Glues on easily.
Darren
I am going to be looking to see if I can fit straps over mine during the rebuild, just for piece of mind anyway
Thats if I get that far
