Spoke to Omex this morning about running the duratec on one of their ECU's in light of this weekends problems
http://www.locostbuilders.co.uk/viewthread.php?tid=134813
Extremely helpful, they have done it before with no major hiccups. So fingers crossed.
The other massive benefit is that I can get it set up on a rolling road a lot easier and hopefully quicker as its a more widely used system with a lot
of knowledgeable people using it.
Ok its not a cheap fix at the best part of £800 but having heard what the experienced tuners have all said I am hoping its the right decision.
I will still be resoldering the megasquirt tonight and getting that fixed to sell on. I'll test it first and check its working of course. I am
pretty certain its a dry joint on the processor socket which has caused the problem.
Will you get it and installed in time? Lesson learnt, get the best stuff from the start Thats what i've learnt building mine anyways
I have run MS for 18 months or more without problems. I have only started having issues since its now doing spark control as well and since upgrading
to MS2.
I dont doubt there is anything wrong with MS at all - it certainly works very well for what it is.
My concerns have shifted from being able to map it myself on the road to just getting it set up by a pro on a rolling road, controlled environment.
This is for 2 reasons - 1 being I want to get the best out of it having spent so much money on the damn thing, 2 being its easier to see what effect
the changes are making when its on a rolling road. Plus its impossible for me to map the higher RPMs as the road speed is just way too high (90mph in
3rd...)
I have learnt a huge amount by doing it myself with megasquirt, and the car itself is (or was) running pretty well up until the latest issue. I dont
regret using MS at all but have been toying with changing to Omex anyway due to the reasons above.
Theres something to be said for listening to the advice of people who tune cars day in, day out who have experience with both MS and Omex and they all
say the same thing - the Omex is much easier to map and a lot more refined around the edges which essentially results in a more driveable car.
but the big question is, will you be at stoneliegh or not in it?
Probably not now.
Sorry chaps.
I'll be there anyway if its any consolation
The change to the omex ecu shouldnt take too long, its a case of how well it runs and assumes no other problems in the mean time.
If I find an obvious problem with the MS tonight then i will just refit that for stoneleigh and risk the journey.
But if there is no obvious fault, then I am not risking breaking down on the motorway.
I'll volunteer to follow you in case. But can't trailer with my car incase anything happens, just moral support
Well, I have ordered the Omex and it should be shipping today.
Andy who I have been dealing with is very helpful and knowledgeable indeed. He is going to do his best to write me a base map for the engine based on
their experience of setting up similar spec engines and based on my current megasquirt map.
It shouldnt be a major job to swap it over as the connections are virtually identical, I just need to splice the Omex ECU into the existing MS
loom.
Then its a case of how well it runs with the base map (if at all) and how quickly I can hone the map at least for just cruising if nothing else.
Then its a trip to either ATSpeed or Northampton Motorsport for a dyno session.
+1, Will you be Alex?
But you could push your car to stoneleigh
out of interest, why omex over, for example, emerald?
I need blended map and tps tables for my engine and I dont think Emerald are able to do this.
Similarly I know that omex have run supercharged duratecs in house (they built a westfield demo car with one in the same setup as mine) so they have
experience in house of these engines with superchargers bolted on...
ouch, another chunk off money, hope it all works out well through.
stuart
My omex 600 on a zetec has worked without any problems for the last four years. Sent it back to them for a free firmware upgrade last year. Software is very simple and Andy is easily available for advice and free base maps when I changed from silver to blacktop to ST170. Only issue is no pwm cam control on the 600.
