I am looking for an idle valve for my zetec on gsxr750 tbs
I think it needs it during warm up.
Which idle valve has an in/output that takes between5 and 8mm hose.
You could use the standard ford one and make a little adatpter with a couple of stubs ?
cheap and easy to get hold of.
i do have the ford ones, but was hoping for a neater solution,
The ford ones just have a flat face with a couple of holes.
We use the Citroen/Peugeot 8V TU engine idle speed control valve.
This would be from a Saxo 1600 VTR, Pug 106 1400XSI, 1600 Rallye. It has a facility to attach it to a hose so can be mounted anywhere you like.
Lars, i never needed one, i just played with the warm up enrichments.
It takes a few goes and normally soots out the plugs as your trying, but worked a treat.
ATB Dan.
I still don't think you will get enough air down the little tubes on those TB's. I know it will be some, but I don't think it will be
enough to make a big difference.
On the other hand you guys with car engined get much more of a vacuum at idle than I can manage.
Matt
I could get an idle anywhere between 900-1600 depending on setting. sometimes even higher with an air leak
ATB Dan.
