has any one got a base map or file i can load on to my megasquirt to get the car running well and maybe get it thought the iva on the emmissions
what i have is
megasquirt 2.2v
with code 029y3 loaded
i have a black top zetec running gsxr k1 600 throttle bodies and injectors
with edis
i have a nomal 3 wire lamba sensor also have a aluminum airbox with a cone k&n fiter
im using a 200 cell cat
i have had the car running but thats it it revs up ok
i have set the tps up fine
any help would be great or a map
or am i going to have the car put rolling road and set up that way to get though iva
i dont mine doing that after but i dont have the spare cash now just would like the car on the road
im going to take it for a mot to check before the iva
cheers doddy
Get full copy of tunerstudio - the "auto mapping" sorted mine out great need to run int under load though because free reving it has left
flat spots.
Have been told but not tried that a wideband lamda sensor will help lots compared to the narrow band one....
[Edited on 16/606/10 by mad4x4]
Been running Tunerstudio for a bit and now it wants some cash to carry on!
The VE analyser has gone... WTF!
have downloaded tunerstudio will try it at the weekend cheers doddy
I have the same setup but with a wide band, I have attached the fuel map.
Paul
And this is the ignition map
cheers paul will give them a try
