hi iam afterone, where the cheapish place to get one, i need just the sensor. does any road car hae them as standard .
adam
I believe that some newer cars are starting to design them in but they will be even more expensive to buy than the Bosch jobbies sold on eBay
like this one
As a matter of interest, you say that you just need the sensor - what controller have you got?
[Edited on 10-8-10 by RazMan]
Originally posted by RazMan
I believe that some newer cars are starting to design them in but they will be even more expensive to buy than the Bosch jobbies sold on eBay like this one
You'll still need a controller, I don't think that ECU has built-in capability to read directly from a sensor.
You need to get something like a Innovate LC-1
Meerkat man,
Not as far as I know! (and I've got one).
Might be a feature of the MSnSE or one of the very new versions, but my MS II v3.0 most certainly required a controller (LC-1 in my case)
EDIT: Unless you mean a narrow-band in which case, yes it should work directly with the ECU (although I wouldn't use that for autotune!)
[Edited on 10/8/10 by PSpirine]
Have a look on here for sensors.
http://www.gendan.co.uk/index.php
Adam, check to see if your ECU (you haven't named it yet) has a calibration function - these things are absolutely useless without it. My MBE
still requires a controller (I have the LC-1 too) to produce a calibrated signal which it can use in a live map. It will however take a narrowband
output directly and you can vary the amount of correction in the software.
You need a controller to work with a wideband lambda, they need calibrating and their heater needs full-time control to maintain the correct operating
range, this is what the LC-1 does. The MS does not have the ability to drive this. Operating the wideband sensor without its heater will rapidly trash
it. Other aftermarket ECU's may do (though I dont know of any, most assume you have the LC-1 style controller and are just feeding the 0-5v
signal in), but they'd need 5 specific wires to connect to the sensor, not just the one of a narrowband and a software tweak.
[Edited on 10/8/10 by coyoteboy]
