Anyone know of a rolling road that will map megasquirt cars. Got mine running on MS, but not driving, just thinking ahead to getting it mapped. BTW
somewhere in Scotland would be nice
Scott
Extreme motorsport in whitburn did mine
What did they charge Andy? Plenty of places I asked didn't want to touch it, and others wanted upward of 75 quid an hour and 4-5 hours to map mine, so I did it myself on road which I'm fairly pleased with but wouldn't really recommend unless you like spending a lot of time and fuel blasting around the local hills!
these guys claim to do it: http://www.wallaceperformance.co.uk/power.htm
(not delt with them myself but I sort of know one of the guys, not well enough for a discount though )
[Edited on 1/9/2010 by mcerd1]
Originally posted by coyoteboy
.... but wouldn't really recommend unless you like spending a lot of time and fuel blasting around the local hills!
Thanks for the info, do you know if they will map a MS car?
Stand Alone Management
Apexi
Autronic
DTA
Emerald
Gems
Hydra
Megasquirt
Motec
Omex
SimTek
Wolf
Many more, all systems looked at undertaken
Scott it was wallace who did scoobylav's and big Daz's avon. I have asked them about doing mines but at £80/hr decided to get it as close as poss myself using tuner studio
Correct but the mapper was Russ Paton who is now based in Dalgety bay Edinburgh at Performance HQ
http://www.hqgarage.boschauto.co.uk/
So give them a shout for more info. closer to you too I would imagine.
Daz
Daz
If you have a wideband lambda you can get it pretty much bang-on with a reasonable but conservative ignition table, then take it to them. The problem
I found though was that they* basically said that to map it they'd wipe whatever I did and start from scratch anyway so there was no point.
*one or two rolling roads I contacted.
Was running and revving but not freely and way overfueling. I did a little tuning with a wideband 1st but its no easy trying to press a button while
the whole car and laptop screen are vibrating wildly
Daz
Cheers for the info, I actually know Russ, he used to come down to Crail quite often with his hot astra.
One question, how close was your car to running before russ got it. Mine will idle and thats about it!
[Edited on 2/9/10 by phoenix70]
