does anyone know if i can run a mbe 967 ecu on a turbo engine
Yes the 967 will control a turbo charged engine. A seperate boost controller will be required tho.
However i would recommend an Omex 600 over the MBE. The price is around the same and both ecu's will produce the same end result. But the
customer support the comes with the Omex system is unbeatable. And sometimes help and advice can be priceless. It also takes less time to map so can
be cheaper in the long run.
Im not just trying a sales pitch here just because i sell them. I actually sell both products. I sell them because they are simple and a good quality
product. We use them on our own cars.
Ian
