A decent meter so I can monitor my fuelling
I'm after a kit complete with the meter, lambda and boss to weld in, any ideas??
Do you mean wideband controller and sensor?
Like the lumenition ones just showing how rich it's running so I can adjust the power commander
Innovate LC1 with a matching gauge is pretty good, type lc1 into eBay to get an idea
Adrian
Adrian
You can get a Innovate Gauge to get with it
INNOVATE DB RED LED WIDEBAND GAUGE KIT, LC-1,02 SENSOR on eBay (end time 10-Feb-11 19:41:57 GMT)
This yeah?
Cheers guys
That will do the trick! Also still have the option to download to laptop. Also, don't know about power commander, but with most aftermarket ecus
you can connect it to the ecu to allow you to run closed loop lambda control that adjusts fuelling as you go - nice bit of kit for the price!
Adrian
