Hi all,
Does anyone know what the "Renix 44-2-2" setting in the ignition settings of tunerstudio is?
I had a thought that may make my wiring slightly simpler by using the existing flywheel pickup point for the ignition.
Engine is a Renault J7R 2.0L
Thankyou.
[Edited on 23-1-11 by MakeEverything]
It is for the fuel injectors used on certain Renault and Jeep models, if you have normal Bosch pattern injectors you don't need it.
Originally posted by MakeEverything
Hi all,
Thankyou.
Thinking of ditching EDIS then?
It's to use the slightly odd trigger wheel pattern a lot of Renaults used to use (the R5GT for example).
