Hey Guys
Just wanted to know who is out there running MegaSquirt on a turbo'd engine.
Can you list your MegaSquirt Version and what engine you are running. Also have you mapped it yourself or got someone else to do it and what your
feelings are towards MS in relation to running a turbo'd engine, Does it run well is it problematic etc etc.
There is a reason i am asking this all will be revealed later.
Ash
Blade megasquirt turbo, its fine for tracks.
Pre-turbo faster on TB's than carbs.
I used autotune and wideband to set up originally, then tried megatunix but never felt it was correct, visited a rolling road and they found another
25bhp, better starting and running across the whole range than I achieved using megasquirt type tools but I was using a JAW as WB.. this is rubbish
should have spent the money on something better which may have improved things.
When I mapped I logged the MAP bins and clustered mapping points around these and RPM most used.
Squirt only, v2.2 running megasquirt extra which gave me lots more mapping points as I started off with the early small resolution table.
The system can run spark as well, I could not be bothered as it does not pink and produces good HP.
In summary, happy user need RR to fine tune.
Regards Mark
I believe MadTeg is running megasquirt and Turbo on a 2.0Zetec hybrid.
About a million MX5s are running turbos on a megasquirt at mx5nutz.com
MS2 running sparks and fuel v2.1.0d of the software but with a home grown modification to use stock ignition wheel. Was running alpha-N. Mapped
using LC-1 Wideband, all seemed to work nicely.
Only just put the turbo on, it idles and revs up, but haven't been for a drive yet. Changed control to speed-density but I don't
anticipate any particular problems.
Possible issues:
The stock pressure sensor goes up to 250kPA (1.5bar), but this is more than enough for me though, other pressure sensors are available.
Check your favourite rolling road are able to deal with MS.
MS1 v3 running the Extra Hi-Res code (can't remember what version), it's running squirt, spark, boost control and closed loop lambda using
an LC1.
Engine is a home-brewed 2.0 Zetec turbo conversion, it goes very well!
Tom
Is this to do with your Saab engine ash? Have you considered tuning the Original ECU?
I've just got my Trionic ECU hooked up to the PC as of last week (for which thanks lie with 'The ECU project' ) , at this point
mapping it incredibly simple to do (I'm not saying it's easy to get it right though!).
Maybe you have other plans though!
Kev
P.s. Auto mapped mine for 260 (ish) bhp via the auto tune function, hopefully having it's first start this week after finally finishing the
wiring loom, someone keep their fingers crossed for me!
[Edited on 10-3-11 by flibble]
yeah it revolves around running the saab engine. i dont have the saab ecu otherwise i would have used it.
I have installed an ms3 with the MS3X sequential card plus a few other personal tweaks. it is installed and running and i have pretty reasonable map
on it working. i have an innovate lc1 for tuning which all seems to work quite nicely.
Called atspeed to book a rolling road session to really hone the map in on their dyno and they said they wouldn't touch mega squirt and that i
should buy an omex. I was a bit disappointed because they did a good job of setting up my bike carbs and megajolt on my old engine and would have
loved to go back to them.
when i enquired as to why they wouldn't touch it they said that it wasn't a professional setup (something that i am well aware of) and that
it couldn't be trusted to run a turbo engine.
now no offence to the older ms owners but the MS3 is a million miles on from the older ms1 and ms2 and the developers have worked very hard to up
their game with faster dual core processors all new code, new tuning software etc etc.
Personally i don't want to spend £600 on an omex ecu then another £250 for the omex loom. Especially when i only paid £100 for the engine with
everything other than the ecu and a 3 month guarantee from the breaker .
I am quite happy to run it on the MS safe in the knowing that if it all goes pair shaped and i pop the engine it will only cost me £100-150 for a new
engine and an afternoon to fit it. now obviously if i had spent 3-4k on an engine i would have just gone and got an omex or emerald as its a drop in
the ocean compared to the cost of replacing an engine but for me thats not the case.
so in summary i really cant understand the logic of it all. the engine is running and drivable, making good boost etc etc. i am well aware of the
ms3 capabilities and limitations and dont expect the same as i would from a £600 ecu. I can't see the reason for the reluctance to put it on the
rollers and have a fiddle regardless of how long it takes as i am willing to pay by the hour.
so thats why i posted to see how many people were successfully running ms on turbo engines as i found the comment from atspeed a bit dismissal
I've run ms on my Turbo engine for years. I don't agree that it can't be trusted -all my glitches have been due to noise or my dodgy installation! Maybe find a rolling road that will allow you to map while they operate the road?
hi ash
i beleive it was ian you spoke to the other day regarding the megasquirt on turbo engine.
im sure you can appreciate that unfortunately, we cannot always give the customer the answer they want to hear.
We have our reasons as to why we are not prepared to tune a turbo engine with megasquirt. We do not feel the system lends itself to a safe and
reliable state of tune, and on a turbo engine where things are so critical, we do not take any chances. Im sure people have got it successfully
working on their own cars, and good on them for doing so. However we are not prepared to do it, it is our descision we do not map turbo cars with any
MS based system - we will not put our name on it.
many other dyno centres also express the same opinion, so not only us.
sorry we cannot be of service on this one.
best regards
colin.
Just find a dyno place that doesn't have the same issues with MS.
Its just electrons running around copper and silicon so there are no real reasons why MS hardware shouldn't be as good (and possibly better, as
there are more installs) than other products. Regarding the actual installs, it is by its nature an amateur thing, so on average I would expect more
bad MS installs than Omex ones, just because we all learn by our mistakes.
I guess the particular issue with turbos, is if the installer has done it wrong then you can get expensive blow-ups, which isn't a good thing for
the RR company. So I can't blame atspeed for their conservative approach, and for explaining their position on here.
Obviously it is also in the best interest of tuning companies to make profit by selling you stuff, and they are unlikely to make much margin on MS
owing to the transparency on pricing and the budget nature of the users, so I'd (cynically) argue that it would not be in their interest to
support MS even if it were fine.
http://www.btecracing.co.uk/ told me that they would map mine if I looked after the MS bits when I called them, so maybe give them a call instead.
I'm going to map it at low boost on the road, because its more fun!
Matt
Hi colin thanks for the reply. I understand where you are coming from and everyone is entitled to their own opinion and to be honest i do value your
opinions. you guys did a great job of mapping my last engine which is why i wanted to come back to you.
i know the omex ecu's are good which is why you recommend them but i just couldn't justify it for this low budget project. if it was my
daily driver then i would be singing a different song right now and you guys would already be mapping its omex ecu. but like i said its a cheap as
chips project and if it goes pop you wont see me shed any tears over it
what is the cost of hiring out the dyno for a session? i don't mind doing it myself but i come you you guys as i value you input and experience.
ash, i will send you a PM.
thanks to everyone for their understanding. we try to help everyone, but its nice for you to see things from our perspective, so we appreciate that
greatly.
colin.
Hi Colin,
I feel very sad reading that you don't tune boosted engines running MSs, but Im not surprised that you have taken that stand.
I've seen some really awfully built MSs that the general public and a company that I won't name, have knocked together, some I wont even try
to repair, let alone plug into my test rig!
But, if built properly, all of the MS's are very very capable ECUs, just as capable as any of the ECUs mentioned in this thread. I've
converted a lot of Tuners over to MS and some very reputable engine builders now use my ECUs (V8D, etc) rather than Emerald and the like, so dont
dismiss the MS.
If built and installed properly, then the MS is an increadable piece of kit! If built poorly then it's not the fault of the MS, its the
builder's fault.
Phil
thats the thing phil. most rolling roads dont have the time to sort out poor ms installs. the nice thing about the omex etc is that they are
essentially closed boxes with a known list of functions etc etc. i personally think the omex is a better product purely because if it doesn't
work as described on the box you can go back to omex and say oi this doesnt work fix it. where as with ms you will get it fixed eventually but you
have to dig and research then work out your own fix using the forums and documentation, or pay someone knowledgeable like you to fix it.
i am a great believer in open source projects and love the concept and learning opportunity that ms presents. if i was racing/competing and just
needed an ecu i could fit and forget then im sure i would just pay someone like atspeed to fit an omex etc and be done with it.
can understand ATspeed stand on not wanting to tune boosted engines running MS and taking the responsibility for the engine staying together.
if it was me i would just look elsewhere, tuners that will map MS systems are thin on the ground though
