Hi Guys,
Just finished installing GSXR6 ITB's & Microsquirt onto my crossflow. It runs, eventually.
Anyway, two questions, first off can Tunerstudio be registered on two pc's as I have the main house one I dabble on & my laptop for being in
the Man room.
I don't want to put it & register it on one without being able to work on the other. Is it a generic code that activates it?
Secondly, I dont suppose any peeps have any base maps I could use to start the tune of my car. It is a 1660cc xflow with stage 3 head, 234 cam running
an edis system
By, it isn't half a steep learning curve this mapping mallarkey. the wiring & the mechanicals was easy in comparison
Cheers everyone, Shane, (York)
the codes are individual to the user. you can run it on up to 3 computers. i have it on 4 now because my old laptop broke doesn't seem to be bothered that i have used the code 4 times even connected to tinternet.
Phil is very good about this (at the moment anyway). He doesn't mind people having a version on a few PC's.
Not sure what the limit is, but if you hit the limit e-mailing him normally sorts things out.
Personally I rarely need the additional features anyway, so using the basic version on the non-car-connected machine might make sense, but if the license covers 3 PCs it's not an issue.
