Having just fitted a high pressure fuel pump inside my tank I got to thinking about an automatic pump cut off.
God forbid I was involved in an accident whats to stop it pumping away, what have you guys fitted, is there an aftermarket cut off switch than can be
fitted maybe behind the dash so it can be re set easily should it get accidentally activated ?
