Hi guys,
Just fitted an external Walbro GLS 392 external fuel pump feeding my Honda VTEC in my middy build.
No leaks, starts well, runs great, but the pump body gets too hot to touch within about two minutes running.
Questions..
1 - Is this normal? can't imagine it is...
2 - If not what could the problem be?
Alan
had this on mine,the inlet was 13mm? but i had put a reducer to make it fit the tank outlet of 8mm?.
the pump always sounded like it was struggling.
pump eventually died,put a bigger tank outlet on and problem solved
all dims are approximate.
Originally posted by Alan B
Hi guys,
Questions..
Alan
Thanks for the help so far.
I wonder if there is fundamental piping snafu?
Originally it had a civic in-tank pump (one pipe out, no return as could see...is this likely?)
I then changed it to gravity feed to an external pump and then pipe up to the fuel rail...there does not appear to be any return piping or provision
for any. Is it possible that there is a fuel return connection that has been blocked off all along?
If anyone has a piping schematic for the 05 civic si that would probably help too.
Alan
I then changed it to gravity feed to an external pump and then pipe up to the fuel rail...there does not appear to be any return piping or provision for any. Is it possible that there is a fuel return connection that has been blocked off all along?
Alan
Did this for another member, may be of help to you. HTH Ray
[img]
Fuel set up
[/img]
Hi,
Some jap cars and bikes only have one fuel pipe to the engine, sometimes the regulator is built into the internal pump housing within the fuel tank. Have a look at the old pump if you still have it, if there is regulator then no problem, you can T into the fuel line and fit an external regulator with a return to the tank.
Don't use the car until you have sorted, overheating the pump (in lockout) will cause the pump to get VERY hot, this may cause a fire!
If it is not a fuel return problem it may be an electrical problem, check that you have a good earth connection also if the earthing wire (if you have one, possibly earthed through body mountings) gets hot then it is a bad earth, especially as it gets hot so quickly.
Originally posted by BaileyPerformance
Hi,
