Ok not sure if this is in the right place, well I was looking for odd bits and have seen this before but forgot but after noticing people saying about
issie with fuel tanks I thort id post this, I know its a bit pricey but givrs an idea for what to look for if you hsve issues with fuel sloshing
about in the tank.
http://www.demon-tweeks.co.uk/Motorsport/Fuel_System/Fuel_Tank_Baffles/Demon_Tweeks_Easy_Pour_Fuel_Tank_Baffle_/1545/0/23019
Bit like .... http://merlinmotorsport.co.uk/product_info.php?products_id=1055%20&utm_source=Google&utm_medium=ShoppingUK&utm_campaign=ShoppingUK ?
Neither are any use if your fuel gauge sender uses the standard float arm.
sorry am I missing something here, aluminium spheres for £40, They look an awful lot like crumpled up tinfoil to me, on closer inspection looks more
like ball of rolled up swarf
It looks like they have their level sender in a still well on that pic,
[Edited on 28/10/11 by liam.mccaffrey]
Was hope their were cheaper way and agreed look silly for the money, I thort for sender to be fitted in a tube with holes in so no interferance from packing it may work with foam but not the balls.
How about this....?
http://www.thefactoryshops.co.uk/rp/products/DZT1009.htm
Cheers R
Originally posted by rachaeljf
How about this....?
Cheers R
I actually know of a team competing with that as a solution. It works (if designed in correctly), don't knock it
Yes it wasn't entirely in jest! Just don't use the ones that come impregnated with soap.
How about this....?
Cheers R
