It's finally available, after good feedback from my beta testers. The app is split into two versions, the first free "MSLogger Connection
Checker" https://market.android.com/details?id=uk.org.smithfamily.mslogger.vanilla makes sure that all the plumbing works between your Android
device and your Megasquirt ECU. If it works, you can then buy for the princely sum of £3 (of which I see £2, so think of it as buying me a pint) the
full MSLogger. Supported firmwares are listed at http://www.mslogger.co.uk/firmwares.html
Regards,
Dave
looks great, is there min hardwear reqm? I'd hate to buy something Android only to find I couldn't then use it for something as fantastic as
this,...
Result!
A lot of hard work went into that. Well done
Do I need some sort of bluetooth adapter for my MS?
Paul
Paul
Originally posted by HowardB
looks great, is there min hardwear reqm? I'd hate to buy something Android only to find I couldn't then use it for something as fantastic as this,...
On the up side of buying an adapter, if your laptop has Bluetooth then you can also use the full TunerStudio with it as well.
Regards,
Dave
wow, that will be great, and I will look out for something in the Jan sales,... don't imagine that I'll have anything ready before then at
the rate I'm proceeding,...
