I've just purchased a 1 litre swirl pot from Alloy Racing Fabrications. It arrived the other day only to find that none of the inlets/outlets are
flared!!
Should they be flared or will this be okay??
It will be fine.
Presure from inlet pump will be <5psi.
There will be little pressure in there as the fuel just returns to the tank.
Use proper hose clips.
[Edited on 13/11/11 by big_wasa]
Cheers biga_wasa, as I thought but I thought I'd check
