I have used mega-log viewer for a few years with no problems but recently decided to do a few runs out logging the car to tweak the map.I data log
with a palm PDA and then transfer to lap top or home pc to edit and have never had any problems but recently all my logs are reporting the wrong TPS
ADC values.My map runs from 63 to 205 ADC and shows that on the palm when logging, but when I transfer to PC it keeps scaling the ADC value as 95 to
189 and is obviously of no use to analyse as the load value is on the wrong areas of the map when analysed .
I cant find any thing wrong with the set up of lap top, pc or PDA and am sure all the settings are as they have always been on all of them.Has any one
else come across this? I have tried reloading the software but have had no success and find it strange that I have the same problem on both desk top
pc and laptop.
Paul
Can you access the raw log on the palm and see the actual logged values? Same on the PC - it shouldn't be scaled during the transfer so it can only really be an interpretation issue?
Try:
Options --> Y Axis Field
change away from TP ADC (i.e. check MAP)
change back to TP ADC, then set the max and min TPS ADC values to anything you want.
Or doesn't that work? Not sure why it should have got changed though.
Matt
On the palm it shows the correct figures whilst data logging but when up loaded its wrong, have just found an older data log and it opens correctly
with the correct ADC values but newer logs don't.
The strange thing is I have 2 palms and both give the same result on laptop or desk pc.It looks as if I will have to wipe everything on both palms and
PCs and try again.
Paul
Yes done that a number of times with the same result, its really anoying as I have the car running the best it ever has but would just like to refine
a few points on the map.
Paul
Originally posted by matt_gsxr
Try:
Matt
