Ok, following on from my recent thread here: http://www.locostbuilders.co.uk/forum/47/viewthread.php?tid=170068
I've now got the megasquirt from my chum & im just trawling through the extra efi site trying to learn about it
Thinking way ahead, im curious as to how/where people have mounted there's, im presuming under the dash board so you can plug a laptop in easily
& keep it out of the weather a little.
Does anyone have any pictures of there set up ?
I have done a search but only found one thread showing an under dash mounting.
Cheers Andy
Mine's mounted on the side of the tunnel in the passenger footwell.
Regards,
Dave
Mine is mounted underneath the engine compartment 'shelf' inside the passenger foot well i.e. at the top of the passenger foot well, the
wiring loom passes straight out through the foot well bulkhead into the engine compartment through a rubber boot.
You can see the LED'S from the driverside when you look underneath.
Mine sits just in front of gearstick under the dash. Serial port and leds just visible. Wires go out through firewall.
Above passengers feet on bulkhead under scuttle.
Not that easy to reach but away from water and heat
Mine is on the rear parcel shelf, behind the passenger seat. You wont have one of those though!!
