anyone know what good new sensors are about sutable for a std build ms2 on v3 pcb
im after an air and coolent temp sensors and was hopeing there was somthing with a a conector you can get plugs for easy and is idealy oem based so
can be cheaply and quickly got from any autofactors
It's setup for GM sensors, but you can tune it for any sensor. Motorfactors will have the sensors but not connectors for them.
Phil @ extraefi has the sensors and pigtails.
[Edited on 25/6/12 by Ben_Copeland]
Here's the MAT sensor I have used, I used the standard Ford water temp sensor Megasquirt manifold air temperature sensor +
connector | eBay
