I'm after some injectors for my Duratec install and came across the following
Racing Volvo Fuel Green Injectors injector T5 T5R Turbo S60 C30 S40 V50 | eBay
Anyone used these and will they be any good for my Duratec or too big??
I was going to use the standard ones but after speaking to Omex I don't think they'll be suitable.
440s are good to about 260-290ish hp depending on the engine etc. If you have an aftermarket ECU to adjust for them they should be ok but you may lose a bit of resolution low down making idle fueling less emissions-test friendly but the extent of that is probably fairly minor.
Racing Volvo Fuel Green Injectors injector T5 T5R Turbo S60 C30 S40 V50 | eBay![]()
I'm hoping for around 200hp and it was just what Omex advised me!!
Those are a bit bigger than ideal, but the only downside might be slightly lumpy idle (as when small amounts of fuel are needed they will need opening and closing really quickly, which can result in slightly random fueling).
