Duratec megasquirt trigger angle MS1-extra
Micael - 22/7/12 at 09:40 AM
Hi guys,
Does anyone have the proper value for trigger angle for 2.0 Duratec, and the value for "trig Pos A"? I use wastefire and not EDIS.
I use 60 degrees as trigger angle and 3 as "trig Pos A". It works but i have to use like 38 degrees advance on idling to get it to run good.
So there is something wrong here.
big-vee-twin - 22/7/12 at 03:29 PM
You should be using 80 degrees as the trigger angle assuming you have the standard 36-1 crank wheel
I'm using waisted spark without edis on my Duratec, but using MS2.
Micael - 22/7/12 at 04:26 PM
I'm not so sure about that.
It looks like MS1 and MS2 handles ingnition different.
MS1
According to MS1 manual the trigger angle should be 60 degrees and trigger pos A should be "3" Which should result in a "true" trigger angle at 80 degrees.
http://www.msextra.com/doc/ms1extra/MS_Extra_Ignition_Hardware_Manual.htm#wheeldecr
MS2
http://www.msextra.com/doc/ms2extra/MS2-Extra_Miss_Tooth.htm
According to MS2 manuel the trigger angle should be 80 degrees and there is no talk about trigger Pos A.
The sensor is on 9th teeth at TDC on a 36-1 standard trigger wheel.
big-vee-twin - 22/7/12 at 04:50 PM
I saw the different manuals which is why I said I was using MS2 -but 80 degrees is the correct angle how ever the software acheives it
Kev
Micael - 22/7/12 at 06:01 PM
Thanks,
I will change the "trigger Pos A" to 2. this will set the trigger angle to 80 degrees... i hope
se7ensport - 27/7/12 at 11:19 PM
I'm using a different ECU, measuring the spark to accurately achieve TDC equalling zero I ended up with a crank sensor setting of 68.degrees BTDC.
