Can anybody recommend a fuel regulator, for a bike engine turbo, I need it to be able to lower base pressure down to 3psi and it needs to rise 1:1 with boost pressure. I have looked everywhere but can't locate one with this spec, most only go down to 5psi. Could you supply links to exact regulators, not just sites as I can find loads of them myself.
I take it that you have carbs on your turbo motor hence the need for 3psi as fuel injection would be a lot higher pressure I would assume.
I would look at a regulator from something like a Mini/Metro turbo as I think they were carb/turbo cars, although I could be wrong.
Some thing like this?
http://www.fuelpumpsonline.co.uk/sytec-turbo-fuel-regulator-carburettor-32-p.asp
As mentioned these only drop the pressure to 5 psi, not the required 3. Yes carbs.
Here you go, 3-15psi with 1:1 increase when referencing boost pressure.
http://aeromotiveinc.com/products-page/marine/13207-marine-a1000-bypass-regulator/
Yes perfect, I would like to try and find a slightly cheaper one but I will certainly keep this as a last resort, I notice you have Mac#1 Turbo, I also have a Mac#1 R1 Turbo carbed what reg do you use and is yours carbed?
Does anybody have a set up for carbs that requires a return to tank fuel line.
Basically I have a fuel regulator that has a return to tank line, I need to know what the best place/way is to connect the return line to the tank?
That want cause me issues with restrictions.
Where does your fuel return enter you fuel tank?
