Hi all,
I'm having problems with Megalog viewer V3.26.1
I've done a search on here and see a number of similar posts and have followed the advice given but still can't resolve the problem.
In a nutshell, I'm running 2.0 Zetec on TB Injectors using Alpha-N. Runs well but have just re-balanced TB's and need to fine tune map.
I have re-calibrated TPS in Tuner Studio which works perfectly but in MegaLogViewer it reads completely differently and the VE Analyse only sees
bottom row of fuel table. I've imported the MSQ used for the data log and I've set the values for TP in the Advanced Settings in Megalog
viewer but to no avail.
I'm running the Lite version of MLV do I need to upgrade to the Registered version as I can't select TPS ADC as an optional field as when I
select "Enable Optional Fields" it just re-directs you to the Web to upgade to the full version?
Anyone help?
Matt
[Edited on 11/3/13 by Bumble]
I had that problem at some point ( 3 years ago)
In megalog viewer in the toolbars look for tps adc and tick the box. It doesn't seem to adapt automatic to the axis scales from your msq for some
reason.
P.s. Am typing this from memory so may be a bit blurry LOl. It'll be something like taht though. There are tps % scales as well so a few
varieties to find the one you need.
Hi, thanks for the reply but I can't select TPS ADC from the pull down box as it is an "optional Field" that is greyed out. When I try
to select ot says I have to enable optional fields which then sends me off to register the version of MLV!!
Matt
We're just talking about this for MSDroid development
Assuming you're running MS1, 'Calibrate TPS' in TunerStudio writes out a
file called throttle.inc into your TunerStudio project directory. You need to find this and then copy it over to where-ever MLV finds its INI
files.
Regards,
Dave
I thought f you had a registered version of tuner studio then the same code allowed you acess to full megalog viewer? Maybe not the case now.
Mmm used to. Mind you was 3 year ago.
Originally posted by scudderfish
We're just talking about this for MSDroid developmentAssuming you're running MS1, 'Calibrate TPS' in TunerStudio writes out a file called throttle.inc into your TunerStudio project directory. You need to find this and then copy it over to where-ever MLV finds its INI files.
Regards,
Dave
I was doing that off the top of my head
I'll dig into it tonight.
Regards,
Dave
OK I was mainly talking out of my backside before
When you do 'Calibrate TPS' it does create a file called throttlefactor.inc in the inc
subdirectory. However when TS is logging, it outputs a % (0-100) for TP in the 5th column of the log file. If you open the MSL file in Excel
(it's a tab separated file) you should be able to find it.
Regards,
Dave
Thanks Dave...but what do I need to do in order for it to work in Megalog viewer? It's reading a TP value in MLV but when looking at the VE
table all the events stay in the bottom row of the table regardless of what the actual TP value is.
Matt
PS......bear with me!!
Hmmm, don't know.
email me the MSL/MSQ combo and I'll have a look in my MLV.
Regards,
Dave
dave.g.smith@gmail.com
Sent you the files to your e-mail.
Thanks,
Matt
