Some advice needed please as I have fairly limited knowledge on Fuel Injection.
These are Bosch Injectors 365cc would they fit/work with Jenvey throttle bodies?
Would they have enough flow for a standard 2.0 Zetec blacktop.
Bosch Injectors 0280155868
HI those injectors will run 212 bhp at 80% and 252 at 90% duty cycle so a bit big for standard zetec
Goggle Stan Wiess injector flow chart
They will certainly flow enough. Really a bit too large, but if you reduce the squirts per cycle then you will probably be fine.
Worst comes to the worst you might get a slightly eratic idle. If you already have them then give them a go, if you are going to buy them then look
elsewhere.
Matt
Thank you very much.
Agree they are a little big for anything up to 200BHP, I've got something like 220ish fitted and work perfect. Also the body looks different to those I use, I'd check with Jenvey.
Thanks I am glad I asked now very helpful indeed lots to consider!
