Hi all
hopefully there is a diagram i'm working from somewhere here . just wondered what I'm looking at re all the pink wires S1-S5
also the wires ending in down arrows on the left . are they bypassing the relay board and going straight to their intended destinations ? plus which
are relevant for an edis setup.
it's getting late
so perhaps I need to retire for the evening
I am thinking of 'microsquirting' my Fiat t/c in my Striker but sorry I will not be using a relay board so can't help
However I will be watching your progress with a lot of interest
Originally posted by peter030371
I am thinking of 'microsquirting' my Fiat t/c in my Striker but sorry I will not be using a relay board so can't help![]()
However I will be watching your progress with a lot of interest![]()
Think I've sussed it , following the instructions from Trigger Wheels and a couple of diagrams I now have a microsquirt to relay board cable for
edis
[Edited on 24/4/13 by Valtra]
I was just looking at your pictures, where did you get your Trigger wheel/ crank pulley from? It looks very neat
Hi
I bought it from Trigger Wheels in Ely who also supplied the Microsquirt
They are not far from me.
It's just a laser cut ring gear which I super glued in about the right position , clamped, heated on a camping stove and stick welded. Then my
mate centred it on a lathe to remove a little run out.
I was just looking at your pictures, where did you get your Trigger wheel/ crank pulley from? It looks very neat![]()
