Evening,
I had the car running today to do a final test of the cooling system, all went well. Tonight I noticed the fuel tank had slightly changed shape. I
looks like the top of the tank has been pushed in. My fuel cap is
this one from CBS.
Now I could not see any difference between different types, the wife brought it for me for Christmas so she rang cbs and asked which one to order for
my type of fuel system (I had written it down in case she rang and was asked any questions).
So it looks like my fuel tank is creating a vacuum as when I released the cap there was an intake of air and the tank popped back up. (this was only a
few mm but noticeable)
Any idea's as to whether I need a tank vent and if so what type? I don't know much about it to be honest, I thought the vent was in the
cap??
Help please
Yes you need a vent and no that cap doesn't have one.
Yep you need a vent.
It needs to let air in to replace the fuel, let air out to allow for expansion on a warm day yet not loose fuel if you tip the car upside down.
OK shi*t,
so can I add a vent? Or new cap?
You can add a vent easily using an aircraft tank fitting
I don't understand how that would work, obviously it would vent the tank, but what about spillage? Would I then have to add a two way valve to allow air in and out and to prevent spills should the car and upside down?
I can exchange my fuel cap but mine fits a 62mm hole and the vented cap fits a 57mm hole. Need to get a easy quick fix asap as I'm about to apply for IVA![]()
I see the add on valves are quite expensive, so I could just try and make the smaller new vented cap fit? what does any one think?? I'm now getting a tad pi$$ed off with things just as I seemed to be making progress again![]()
Don't drill a 0.5inch hole with that, used a stepped cutter. The drilled hole will not be circular and it will leak. I learnt that one the hard way.
Good advice![]()
0.5inch is 12.7mm. Try a 12mm hole and put it in with violence/lubrication
I ended up buying a new tank and didn't bother with the fitting in the end. I had bought it so I could avoid taking my tank out, but as I ended
up having to use a new one, I did it a different way.
Regards,
Dave
Why not fit a breather valve to your tank?
Like these ones
http://www.thinkauto.com/onewayvalves.htm
They you don't have to incur the stress and marital strife of returning the cap, and these work really well.
Matt
There's lots of info on here about the breather valves. The ones that let air in and out but not fuel in case of a roll over. You can create the same effect with a pipe routed the right way. I shall try and find a picture
See daviep's great idea on this thread. breather pipe thread
