I'm in the process of building the engine loom for my Duratec engine. It looks like the total cost of going coil on plug is about the same as a conventional coil once you have factored in a set of HT leads. Which approach do people recommend?
Coil on plug.
You get a better spark because each individual coil gets longer to charge, rather than wasted spark, where you have one coil firing twice per four
strokes, which means the other time it fires is on the exhaust cycle of a opposing ignition cycle, hence the moniker 'wasted'. Sp, IIRC, the
coil pack on your (and my) duratec is wasted spark.
Then there's the final system, which is conventional coil, which fires every ignition cycle and is a lot bigger.
On my pinto (so it's not relevant here), I used MSD capacitative discharge, controlling my coil. It was excellent and from the moment i fitted
it, my awkward to start pinto became a dream to start. It would usually light up first turn of the crank from cold, no choke.
This is a quote from SBD who fit COP and why they do it (its talking about the loom kit they sell);
It has been made to fit the coil on plug version since the coils are cheaper than buying the older coil pack & HT leads. They are also neater
with fewer components to go wrong & when used in cars such as Escorts, there are no problems trying to locate the coil pack.
I already have a perfectly good coil pack and HT leads so my build will stick with that but if you are replacing these then it looks like the
economics alone is a good enough reason to go COP to me
I've been trying to find the reference in Haynes fuel injection book, but can't at the moment. I also have a ignition book as well that
i'm trying to find.
For me, packaging is also important. I'm lucky that in my fury, the coil pack and thermostat housing fit as per, but I don't want to use the
coil pack.
Better sparks mean a better burn.
COP produces no better spark than a coilpack.
We tend to favor Ford coilpacks as we have found these to be better over most COPs assuming you have decent leads.
In my opinion COPs can suffer from overheating due to there location, (reducing there output)... a happy coil is a cool coil!!
Thanks for the input.
@baily performance how have you found the conventunal coil to be better?
I use a ford coilpack on my turbo ZX9 engine, I used some dwell settings found online for megasquirt and it works a treat so I agree that they can
withstand high/incorrect dwell settings just fine.
I run 15psi of boost and 13k rpm rev limit and have had no spark problems
What sort of increased dwell times are you talking about here in these extreme circumstances? just interested that's all
Ian
Ian
you could always go for CNP and choose the LS2 truck coil.. They read like they are very good and I went for 8 of them.. (to be honest mainly to do
something different to a couple of ford units as I don't have a mega high performance car)
http://www.megamanual.com/seq/coils.htm
you will need different HT leads as the coils have different sockets, I got mine made up in the US.
