Hi all,
i have brand new ZETEC black top 1.8 i also have multiple ECUS
1- 98AB code REAR with key 60 pin
2- 97BB OWLS no key 104 pin
3- 98BB NEST 104 pin WITH KEY (MONDEO) with the exact wiring loom starts with white blue in 13 and black yellow 103,i have been searching on the
forum, and the diagram i have managed to find the colours do not match the colours of the wiring loom that i have. this is quite confusing.
I also have the wiring from a focus and but the wiring doesn't match the wiring in the haynes service and repair manual.
My question is, which one of these ECU's will be the best for my engine and where will i be able to find the wiring diagram suitable for the
ECU'S that i have.
My 60pin wiring from a Focus 1998 starts with a red in number one pin.
Where do the PATS connect? Where can i connect the LEDS & the diagnostic connections?
ANY OPINIONS AND HELP WILL BE GREAT! THANKS
TOPYLITA
Have you read this? http://www.locostbuilders.co.uk/forum/47/viewthread.php?tid=179921
You have a 1.8 blacktop engine, loom and ecu so it makes the most sense to use them together.
The Owls ecu with out key is bin fodder.
Keep the nest ecu as that could come in handy.
The info in the link above is for the 104pin looms. I cross posted on the Haynes forum and with me filling in a few blanks "Shorty". Listed
the 60 pin black top pin outs.
Enjoy
Pin No-Colour-Function
1-Red-Battery
2--
3-White/blue-Vehicle speed sensor (VSS)
4-White/purple-Audio/cruise/trip
5-White/green-Immobiliser control module
6-White/red-Air con
7-White/purple-Cylinder head temp (CHT)
8-Green/black-Fuel pump relay
9-Purple/blue-Mass air flow (MAF)
10-Green/yellow-Air con
11--
12-Black/white-Injector 1
13-Black/blue-Engine coolant blower motor relay 1
14-Black/orange-Injector 4
15-Black/yellow-Injector 2
16-Black/yellow-Earth
17-Orange/black-Data link connector
18-Blue/black-Data link connector
19-Grey/orange-Data link connector
20-Black-Earth
21-Black/yellow-Idle air control (IAC)
22-Black/blue-Evaporative emissions (EVAP)
23--
24-White/purple-Camshaft position sensor (CMP)
25-White/purple-Intake air temp (IAT)
26-Yellow-Throttle position (TP)
27--
28-White-Power steering pressure(PSP)
29--
30-Brown/white-Camshaft position sensor (CMP)
31-Black/white-Engine coolant blower motor relay 2 AC
32-Black/red-Starter motor relay
33-Black/yellow-Heated oxygen sensor (HO2S)1
34-Black/blue-Injector 3
35--
36--
37-Green/yellow-Engine control relay
38-Grey/orange-Immobiliser control module
39-Black/orange-Immobiliser LED
40-Black/yellow-Earth
41-Blue-Alternator
42--
43-White-Clutch pedal position (CPP)
44-White-Heated oxygen sensor (HO2S)1
45-Grey-Alternator
46-Brown-CPP, CHT, HO2S, IAT, TP
47-White-Throttle position sensor (TP)
48-White/red-Heated oxygen sensor (HO2S)2
49--
50-White/blue-Mass air flow (MAF)
51-Black/blue-Heated oxygen sensor (HO2S)2
52-Black/green-Ignition aux circuits relay
53-Black/blue-Fuel pump relay
54-Black/yellow-AC compressor clutch relay
55-Brown/red-Crankshaft position (CKP)
56-White/red-Crankshaft position (CKP)
57-Green/yellow-Engine control relay
58-Black/red-Ignition coil
59-Black green-Ignition coil
60-Black/yellow-Earth
So how did you get on ? Some follow up would be nice !
