Hi all,
I'm looking for some 250cc plus side feed injectors and was hoping to find a list of vehicles which has these as standard.
Nissan 200sx
Nissan 300zx
Subarus
Anything else I can look out for?
I have been looking into this as well as I need to swop from Methanol injectors to Petrol (about half the flow). There are lots of big side feed
injectors for SR20DET engines. I would love to find some dimensions and see if there are any common standards.
I will follow this thread with interest.
Try this, might help ? http://passionford.com/forum/technical-help-q-and-a/459718-nissan-subaru-injectors-zetec-fitment.html
i believe MR2 Toyota 3s-GTE engine has side feed injectors
Thats the MR2 mk2. Revision 2 injectors are 440cc and cheaper then the later rev3 injectors which are larger cc and slightly different size.
I am running yellow 440cc subaru side fed injectors in a standard ford fuel rail, would think this would be ok for you.
540cc in the latter 3SGTE Engine. Also found in Celica gt4...
I've a couple of sets knocking about if you need any info, I'm looking at converting to 800cc end fed so I've got most bits off just
now.
Thanks coyoteboy but I've made the jump already and chopped the side feed and used it as a boss for the black top rail. It's a bit messy but there we go! Thanks for the help!
