Zetec Build
the_big_1 - 13/3/17 at 08:17 AM
Hi guys,
I have a Zetec silver top bare engine already.
Don't want to get a doner car as no room for it etc.
I have a brand new black top inlet manifold complete with injectors and sensors etc.
Black top ECU and wiring etc.
Question is, would it run ok??
Wiring is no issue etc as I do this for work.
hughpinder - 13/3/17 at 12:53 PM
I suggest you search for posts from big_wasa, a user on this forum:
Here is one of his posts:
http://www.locostbuilders.co.uk/viewthread.php?tid=179921
Best of luck
Hugh
big_wasa - 13/3/17 at 01:54 PM
Yes it will run fine. Blacktop ecu = blacktop sensors.
By that I mean maf, tps, air and coolant temp.
The rest should be fine.
I've done it both ways and seen them through Iva.
It will top out around 135~150bhp depending on breathing mods.
Can you get the inlet manifold to fit the chassis and the steering column link.
Westfield produced a nice air box for there factory oem setup.
the_big_1 - 13/3/17 at 02:46 PM
Fantastic!!! Top man!!!
What breather mods would increase the standard BHP?
Chassis will be fine, or should I say on CAD it is lol
big_wasa - 13/3/17 at 09:09 PM
Ditching the standard manifolds.
the_big_1 - 13/3/17 at 09:12 PM
Arrrrrrr you mean going the carb root?
That was a plan to go after IVA emissions etc.
big_wasa - 14/3/17 at 06:50 PM
No, Oem injection. But to release the full 165 ish the Zetec is capable of you would need to ditch the Oem ecu.
the_big_1 - 14/3/17 at 07:34 PM
Ohhhhhhh so there is a replacement injection ECU, also runs the ignition or piggy back? Same injectors?
Obviously long after IVA lol
big_wasa - 14/3/17 at 08:04 PM
No cross purposes here.
Increased breathing abilities with four branch exhaust and a plenum or throttle bodies all run from the Oem ecu will give around 150bhp.
To go beyond this will require a flexible solution like a mappable ecu.
