Car running issue (runs fine when a HT or injector unconnected)
ch1ef - 23/10/17 at 08:44 PM
I have a Zetec with Megsquirt V3 on throttle bodies.
The car has been unused for about 4 years after a crash, and now I am trying to get the car back going. The car starts and runs, but I had to tighten the throttle cable a tiny so it runs 1200rpm at idle so it would runs on its own. But its super rich (black smoke). I can remove an injector wire (any for the 4) and it runs almost the same, and I can also remove unsurprisingly any single HT lead and it similarly doesn't change much either!
I have checked wiring to ECU, earths and everything else I can think of to check, any idea's? I do have a cable coming so I can hook up the laptop, but its being slow getting to me....So, Any pointers?
gremlin1234 - 23/10/17 at 09:21 PM
check for spiders webs, (or even a bird's nest! ) in the air filter ;-)
ch1ef - 23/10/17 at 09:23 PM
haha! Def none of those as only just put the filter on the truppets!
rusty nuts - 24/10/17 at 05:08 PM
Could be sticking injectors , faulty fuel pressure regulator maybe faulty temperature sensor, few things to be going on with.
obfripper - 24/10/17 at 06:16 PM
Is it running speed density (map sensor fueling) or alpha n(tps based fueling)?
If it's sd, the vac hose to the sensor (usually part of the ms ecu) is probably perished/disconnected, and so giving a wot signal to megasquirt which will be super rich at idle throttle openings.
The same can happen with alpha n if there is a tps fault, but is less likely and it should default to closed throttle signal with the sensor disconnected.
Dave
