I have my V8 starting, fast idling, warming up ok and ticking over strong.
I have a hesitation pressing the throttle from idle, does anyone have a Megasquirt RV8 map I can take a look at see how no load pickup is handled in
the fuel table.
This is acceleration enrichment? Could never get my head around this! Stopped it stuttering/stalling by running VEAL with the lower threshold 100RPM
above idle then doing a lot of standing starts from idle either on the drive or actually driving.
Should say that this was with moderate pedal movement speed, never got it right when stamping on the pedal, but once it was over 1500RPM was okay.
[Edited on 21-2-18 by 40inches]
Cheers Dave, I’ll have a play, Im thinking I’ll just go richer at the top of the table until the hesitation is gone, I was leaving AE alone as per
Phil’s (extraefi) manual.
Must master ve analyse though....
Is it using a wideband 02 ?
Yes mate, Im running a wideband.
I drove mine around with ae turned off and let it sort itself out . Steady throttle application and it was pretty close after a couple of hours , turned the ae back on and it drove fine just needed a few tweaks on the Dyno
