What is the best HP electric fuel pump to go for at a reasonable cost? Will be running max 200hp non-turbo on a zetec on TB's.
In tank or inline fitting?.
Ian
Inline
From JJC RACE and Rally Universal External In-Line Fuel Injection Pump Bosch 0580464070 Replacement eBay item number:361025345369
Been using mine for 10 years with out any problem.
good to know that you have had no issues with yours. Always a bit put off by the cheap pumps due to the amount of trouble people seem to get with them.
only buy genuine Bosch.
£90 Burton Power, in line.
Pump feed MUST be 12mm bore, gravity fed, no pre filter, filter after pump.
Wouldnt trust anything branded from JJC to be genuine
I bought an APS branded 044 equivalent from JJC and it started to fail after about 6 months and it was horrifically noisy straight out of the box. I
was having problems with fuel delivery over 5k rpm and the pump was the culprit. I couldn't recommend you to buy one. I have since bought a
genuine 070 Bosch and it's a lot quieter and delivers what it says it should at all engine demands. The Bosch draws a lot less current as well
which has helped my battery issues a lot.
Chris
Genuine Bosch unit it is then!! Why no pre-filter? I have a swirl pot for it to run from my existing carb pump, not sure on the outlet size though
Originally posted by CTLeeds
I bought an APS branded 044 equivalent from JJC and it started to fail after about 6 months and it was horrifically noisy straight out of the box. I was having problems with fuel delivery over 5k rpm and the pump was the culprit. I couldn't recommend you to buy one. I have since bought a genuine 070 Bosch and it's a lot quieter and delivers what it says it should at all engine demands. The Bosch draws a lot less current as well which has helped my battery issues a lot.
Chris
044 refers to a bosh part number, and the Bosch pump was an oe application pump. Like a lot of pumps though, they don’t like sucking on air.
Only commenting because when I was trying to find info, before I bought a pump for the Jag engine
I found an article on the Bosch web site, of course, now I can't find it![]()
Can only find this Link
[Edited on 13-3-19 by 40inches]
When i built my new project i fitted the 'equivalent' of a Bosch 044, labelled as a DA31. Nothing but issues and the noise, the video below
doesn't really show how loud it was!
16mm pipe feed, pump directly under the tank, no pre filter so the feed side was spot on.
Bit the bullet and bought a genuine 044, night and day difference and quiet. I did a video on youtube showing the difference in noise, straight back
to back just swapping the pumps;-
Ian
Originally posted by Oddified
When i built my new project i fitted the 'equivalent' of a Bosch 044, labelled as a DA31. Nothing but issues and the noise, the video below doesn't really show how loud it was!![]()
Bit the bullet and bought a genuine 044, night and day difference and quiet. I did a video on youtube showing the difference in noise, straight back to back just swapping the pumps;-
Ian
Just about to order a 0580464070 bosch pump.
Do i need a pre-filter or not?! Some sites say you must, others dont mention it at all. Will be running a filter from the LP pump to the swirl pot
anyway, and then a HP filter from the outlet of the pump, so dont see any benefit to be honest!
Don't run a pre-filter, especially if you have a swirl pot and filter on the feed to that. It's only asking for problems with fuel
flow/cavitation.
Ian
Bosch 044 and they're not expensive.
ok to filter.
Dont need the output of the 044 pump and the 070 seems to be more than sufficient and a lot lower cost
Originally posted by ttalps2000
ok to filter.
How much is a 070 pump?
£93 from Burton power
