Hi guys,
On many of the pin out diagrams including the fabulous one on here, state an "Exhaust pressure transducer" what is this, where does it live
and do we need it on a silver top Zetec using blacktop ECU etc?
Many thanks!!!!
I don’t know what your reading ? But it’s not anything of mine unless you mean somthing differant.
Egr ..exhaust gas recirculation.
Evap..Canister purge valve
Hi ya,
Pin 65 on the black top ECU says
65 white/green -- exhaust pressure transducer signal(large plug ) and I have seen this sensor shown on a few schematics and the plug I have has a wire
in this cavity too.
All exhaust pressure sensor I can think of are normally on desiels etc
Many thanks.
It's on the egr pipework to detect blockage/bypassing on the later blacktop mondeo/cougar zetecs, i can't recall seeing one on a focus
zetec.
It will trigger a fault code if not connected, i don't know if that code will trigger limp mode as well.
Are you using the blacktop inlet and exhaust system, or using the blacktop ecu with silvertop inlet/exhaust?
Dave
Hi ya,
So far I have blacktop ECU, inlet with injectors, idle valve, throttle position etc.
Nothing for the exhaust so far.
Cheers.
Have a look at these, there's an overview of the egr system and removal of the egr pipework with the pressure sensor pipework location.
https://workshop-manuals.com/ford/mondeo_1997_08.1996-09.2000/mechanical_repairs/3_powertrain/303_engine/303-08a_engine_emission_control_1.6l-1.8l-2.0
l/description_and_operation/engine_emission_control/
l/description_and_operation/diagnosis_and_testing/removal_and_installation/exhaust_manifold_to_exhaust_gas_recirculation_(egr)_valve_tube/
Dave
Hi,
All understood. I wounder if my ECU requires this etc and if not fitted, if it goes to limp mode. other sensor to leve off until I power up nd check
fault codes lol
At this rate, might have to by a scrapper car lol
Ok I did say I was going to give my self a refresher.
As pointed out above it’s a pre 97 thing and is part of the egr system.
It’s not present on the 98 99 system.
Lol lol perfect.
I have designed a whole vehicle schematic so double checking everything lol the Joy's of being an electrical engineer lol
It’s a looooooong time since I’ve played with silvertop and early Blacktop ecu’s.
If the vehicle had it there would be a metal pipe in the inlet. But as your mixing and matching.
With the silvertops that I did I binned the complete Egr system. It did show a code but did not give a limp home mode affect.
I am prety confident your ecu will not suport it any way.
More info here
http://www.gomog.com/allmorgan/ZetecIdleIssue.htm
Fantastic!
Your a top man as usual!!!!
