Hi All
I'm new to the group, i had a quick scout through the posts for any about using speeduino and figured i should offer my services.
I've been part of the speeduino community for about 2 and a half years now as i wanted to make an ECU for my mk1 Astra turbo, i have been doing
electronics since i was a kid i decided i could make my own board for the Astra mk3 (the engine I'm running is a C14SE block with a C16SE head to
lower compression and an IHI 1.7TD turbo at 1bar boost) my goal is 200bhp from the 170bhp it was doing on stock management and a 5th injector, i
originally used the 1300s block with the same head and turbo and made 126BHP at 8psi so i know 200 is within reach easily using the 1400 block and
330cc ST injectors i have.
since doing the Astra board and helping multiple people get their cars running from a few ST170's to a 4.0 supercharged jag V8 i was asked
several times to help with the ST170 wiring for people using the 0.4.3c speeduino board they were wiring into the car, so i designed my own board that
fits the stock case and uses the 60pin header for the stock loom, its fully wire-able to suit any 60pin setup to save making loads of different
versions.
I'm building 5 of the first revision which i have sold all of them so far, hopefully the link works as i cant find a way to insert the image i
have of the board.
i will have some more available early next year once i make a few tweaks etc, i have two versions of the board, one for the narrow internal case and
once for the full width internal case.
The board has the following:
8x 0-5v inputs (TPS/IAT/CLT/O2/Spare 1/Spare 2/Oil pressure/Fuel pressure.
6 high current drivers (4 injector drivers/1x idle/1x boost output)
6x low current outputs, spare 1/fan/pump/tacho/D4(vvt)/D6(idle2).
2x spark outputs to drive a wasted spark coil pack or COP in wasted spark setup.
launch input and a spare input.
2.5 or 4 bar map options
VR conditioner
[Edited on 27/11/21 by RJB.Autoelectronics]
Nice idea making it fit the stock box and connector. My Speeduino is in a generic box with a db37 as the car previously had a MS2. It works a treat and the rolling road guy that mapped it was impressed too so Speeduino gets my vote
