tell me about Injectors
graememk - 8/4/06 at 09:02 PM
how do they work, ie, do they have a permanent live and a trigger live and earthed vie the engine.
or am i wrong and barking up the wrong tree
is the trigger from the megasquirt + or -?
[Edited on 8/4/06 by graememk]
NigeEss - 8/4/06 at 09:19 PM
I always thought they were simply a solenoid with a +ve and -ve.
Unless it a Landy TD5 one which uses some sort of witchcraft
[Edited on 8/4/06 by NigeEss]
mark chandler - 8/4/06 at 09:32 PM
Not earthed via the engine, live feed and injection system pulses earth.
If you run them 100% then they burn out, the fluid going through cools them.
Regards Mark
zetec - 8/4/06 at 09:34 PM
My Emerald ECU has them wired with a common +ve ignition feed and triggers them with a -ve pulse the length of which determines the amount of fuel delivered. Some require a resistor in series to work without burning out the ECU due to too high a current draw. I have Bosch/Vx ones fitted...£25 a set s/h.
graememk - 8/4/06 at 09:41 PM
got it straight in my head now thanks guys.
easy when its explained
