Can anyone tell me what i need to make up the comms lead megajolt to computer and the connections required.
All this info is on the Megasquirt site.
Here it is if you're a lazy git.
On the cable, pins 2, 3, & 5 should all be connected and "straight-through".
Info HERE Step 26
[Edited on 17-4-06 by BKLOCO]
U need a serial lead like that used on a pc mouse(not the round one).
U can buy them cheap enough. Its a straight through extension.
Are the connections for megasquirt the same as megajolt.
Yes the leads are the same , 9 pin male to female straight through on pins 2, 3 and 5. I made several of different lengths and use them for both
applications.
Paul
