There is a small black box joined to the side of the throttle bodies. I believe its the TPS. Can this be used for this purpose.
If yes how is it wired? It has Yellow/Blue/Black wires.
No 1 on this picture
What is the big box marked as 2?
[Edited on 9/5/06 by piddy]
number 1 is your tps (throttle position sensor) number 2 is your cold start set up, hope that helps
Yes I plan to remove the secondry butterflies.
Agree with Mark.
You wont need the second butterfly's but remember to "fill" the holes up.
I used some countersunk bolts and lock nuts with "no nails" squized in. Rock solid
CaLviNx
What have you done for fuel pressure regulator? and fast idle?
Where did you get the air trumpets from?
ok my appologies for the mistake, what are the secondary butterflies for then if not for cold start??
thanks for that calv, i just bought a set of these gsx tbs in bits and am finding it fun trying to put em back together again.
thanks
Thanks again.
The Fidle valve has two pipes.
you've aready said one pipe connects to the original injector holes to get its feed.
does the second one as well or is this connected elsewhere?
Ok cheers.
Those valves are infamous for getting clogged up with black "cheese" from the inlet tract and become very intermittant until you clean them. After cleaning it out about 4 times I almost bought a new one for my Astra GTE16v until I found they were nearly £150 new!
