bike carbs on pinto
roadrunner - 8/10/06 at 06:33 PM
Does any one now how to start a pinto with bike carbs when i am getting a spark and fuel is getting to the carb, i'm also on megajolt,i've flattened the battery twice trying to start the bugger, plus , does any one now the firing seqaunce from a zetec coil to a 2ltr pinto , got ma leads mixed up,
rusty nuts - 8/10/06 at 06:43 PM
Try squirting easistart into carbs . If it's the fueling causing problems it should fire and run for a couple of seconds. Think the firing order is 1 3 4 2 , the coil pack may be marked accordingly. If that dioesn't get you started try changing the leads so that leads 1&4 go to coil positions2&3 . PS brake cleaner is as good as Easistart for starting engines. Could also be your ignition timing out but can't help with timing megajolt system
snapper - 8/10/06 at 07:09 PM
Megajolt uses the wasted spark system so fires 2 plugs at the same time if you don't get any sort of ignition then swap the leads over
roadrunner - 8/10/06 at 07:45 PM
Cheers fellas.
jacko - 8/10/06 at 08:06 PM
Hi Greg i find if i use choke on my car it will not start very easy i have the same carbs as you . I don't know about megajolt but if you u2u Ray ward he may be able to help Graham
TangoMan - 8/10/06 at 09:13 PM
I don't use the choke until it has fired up.
I start on tickover and then give a little choke and revs at the same time.
As has been said, the system fires two plugs at once so just make sure it is firing the correct two.
wilkingj - 8/10/06 at 09:59 PM
I usually just squirt from propane or butane gas from the blowlamp down the carb before rolling the engine over... never fails, unless the spark or valve timing is wrong etc.
