Puzzled by EDIS 4 connector
David Jenkins - 2/1/07 at 07:40 PM
I have 2 EDIS-4 units ready for installation, each with their own connector (I'm only fitting one!). All the Megajolt instructions show a tacho outlet on pin 11, but both of my connectors are lacking a connector in this position. The EDIS units have a pin there, but it's not being used.
Should I be worried about this? After all, there are 2 other ways of attempting to get a tacho feed - the MJ connector and the coil outputs (via diodes).
I'd rather not go looking for another connector as I've been to 2 scrappies today, and I only found one car with the right kind of ignition system - it looks like the older cars are getting trashed ASAP instead of being left around the yards...
cheers,
Surrey Dave - 2/1/07 at 07:44 PM
I think some people have used the edis output , I guess it should work with a Ford gauge ,but most seem to end up using either diodes or diodes+resistor from the coilpack.
So you probably will not need it , it did not work on my Skoda revcounter!!.
David Jenkins - 2/1/07 at 07:49 PM
That's what I suspected - it's just that I'm about to wire everything up, and I don't want to waste time and effort putting in the wrong connector (especially as it's the biggest one...).
How have people arranged the 3 diodes? With a bit of circuit board, or just covered with heatshrink tube?
Surrey Dave - 2/1/07 at 07:52 PM
I cant remember exactly but I know I used some bullet connectors and sleeves so that if the revcounter components went down and messed up my sparks I could unplug them and still get home.
roadrunner - 2/1/07 at 08:47 PM
it's not a problem having that pin missing, it is missing on mine, i just connected the tacho to the white wire from the megajolt.
David Jenkins - 2/1/07 at 09:16 PM
What make of tacho are you two using? If either is an electronic one from CA, Smiths or Greengauges then I'll be well chuffed...
DJ
Marlon - 2/1/07 at 09:20 PM
i have drilled a 3mm hole through the top of my edis plug over where the wire should be, fed a wire through and attached a female pin into the plug. Works a treat.
paulf - 2/1/07 at 11:55 PM
It is possible to dismantle the plug and add an extra pin from a spare plug by drilling a hole in the backing piece. I have not seen many plugs with the tacho pin fitted so it wont be worth looking in the scrapyard.
I used the diode circuit but had a problem with the zener diode breaking down and causing a hard to trace missfire. I am using an old ford tacho and it wouldnt work from either the Megajolt or Edis output but I eventally got a usable signal from the pip signal on pin one of the edis , i just piggybacked onto the connection to the megajolt and it has worked fine ever since.
Paul.
garage19 - 3/1/07 at 07:57 AM
David,
Whenever I have used the EDIS unit on MJ or MS installs I have left the pin on the EDIS unit and used the diode set up on the low tension side of the coil pack. Has always worked a treat. Diodes cost a grand total of 18p for all three from Maplins in town. I just solder and shrink wrap.
So you are dragging that crossflow into the twentieth century!
David Jenkins - 3/1/07 at 08:37 AM
Half-way there, anyway! I've chickened out of MegaSquirt for now...
